T's in CAT's
OR, WA, BC, Alaska, Idaho
FRED
Re: T's in CAT's
Post by FRED »
Thank You Lyle, pictures are great ,pretty well what I want to put on my T.I don't know how to post pictures on this site otherwise I would show you my T.I have built my T with many used parts .mine well never be show quality but a good reliable and driving bucket.Hopefully I figure out how to post pictures.
Re: T's in CAT's
FRED wrote:Thank You Lyle, pictures are great ,pretty well what I want to put on my T.I don't know how to post pictures on this site otherwise I would show you my T.I have built my T with many used parts .mine well never be show quality but a good reliable and driving bucket.Hopefully I figure out how to post pictures.
http://nationaltbucketalliance.com/bb/v ... =35&t=1012
Fred read this link for posting photos to this site........I think this will help you do it.........
Re: T's in CAT's
Amen on posting pix. I managed to stumble through the first time. Now it's much easier. Mike's advice is dead on.
One thing you may have to watch is the size (pixel count) of your pic. If to big, the site will not allow you to post. I have had to reduce the size of all mine, so far......lyle
Re: T's in CAT's
Here ya' go Fred. I was wrong about the size of the oak boards! They actually measure 13".
I have added 1" angle braces in all four corners and on the top piece that the hinge is screwed to.
Using plywood for the top was a mistake, screws do not work well horizontally into plywood, should have used laminated pine available at Lowes/Home Depot :( :( :( Next revision it will be replaced, and that piano hinge will be replaced with a hurricane galley hinge.
Any questions don't be afraid to ask. Have you figured out how to post a pic yet??.....lyle
Battery/Fuel Tank
Battery/Fuel Tank
Battery solenoid master swith
Right rear corner
Right rear corner
Left rear corner
Left rear corner
Semi Loaded for trip
Re: T's in CAT's
Oh, did you notice my hi tech lid prop :?: :?: A left over piece of oak from the top trim. Works great, low maintenance too :D :D :D :D
I sliced off some 1/16x3/4 pieces from the left over oak and glued them to the floor, then set the battery on top of them. Made the battery mounts from 1/8x1" angle and a piece of 1/8 plate.
FRED
Re: T's in CAT's
Post by FRED »
I am still having trouble with the pictures,my problem is Igo to my picture files,I cant figure out how to move them from the files. I will keep working on it.Thanks for the detailed pictures of the box.Looks great,I like the size for holding gear.My bucket has ron popes extended body so I want the box to look proportion to the body.thanks again
Re: T's in CAT's
Fred, send me a pic. lhp2658@q.com I'll see what I can do to post it.....lyle
Re: T's in CAT's
This is Fred's T to Be :)! :)! :)! :)!
Fred's T
Fred's T
FREDS T-BUCKET 553.jpg (69.91 KiB) Viewed 971 times
Re: T's in CAT's
What vehicle is Fred's seat out of?
Thanks,
Re: T's in CAT's
I noticed that last night, too Mark.... I think Fred will see your post and he can answer directly.......lyle
Return to “CATs - Cascade Area Ts”
