Post count and smilies
Loose Ctrl
Handle: LooseCtrl
Re: Post count and smilies
Post by Loose Ctrl »
I'll call this a test post.
All seems to be well.I edited this post.I see the code bar at the top of the post block,and my post count is up.So I guess this is my first offical post since joining. :lol:
Just a bucket I like.
Can't get an image to post using the image code.
GTS225
Handle: GTS225
Post by GTS225 »
Test post for me, too. Let's see if I can edit, and the post count goes up.
Roger
YEP! Post count went to one, and I was able to get back in and add this line.
Loose Ctrl
Handle: LooseCtrl
Just a sweet T I like and found on the net.
[img]Still%20can't%20post%20a%20pic.[/img]
I still can't post a pic using the code above,or any other way.links also aren't posting.The software tries to make the post and then times out.
Lee in KC
Handle: Lee in KC
Post by Lee in KC »
Hey Loose, can you post the address/filename of the photo you're trying to post. Don't use any tags.
Loose Ctrl
Handle: LooseCtrl
Lee in KC wrote:Hey Loose, can you post the address/filename of the photo you're trying to post. Don't use any tags.
Here's the link. http://www.tbucketplans.com/wp-content/ ... ket-18.jpg
Lee in KC
Handle: Lee in KC
Post by Lee in KC »
I couldn't get it to post either. Here is the error message I got...
"It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct."
I have seen this before. Occasionally the forum program runs across an image format it can't figure out. I think you just happened to stumble across one.
Here is the photo your were trying to post. I imported it into my image editing program and re-sampled it, then dragged and dropped it into this post.
Loose Ctrl
Handle: LooseCtrl
That's a sweet little bucket! 'Used to belong to a guy named Carl Libucha, and it has 3 pedals, right ??? :)! :P 8-)
Loose Ctrl
Handle: LooseCtrl
Bill Cleveland wrote:That's a sweet little bucket! 'Used to belong to a guy named Carl Libucha, and it has 3 pedals, right ??? :)! :P 8-)
I don't know the details.I found it while doing an image search.
