membership
Re: membership
Do you have to be a NTBA member to have a "Signature" ??? I can't find a place to
enter one, although I have it set to display signature if I had one.
Re: membership
Indycars wrote:Do you have to be a NTBA member to have a "Signature" ??? I can't find a place to
In the upper right hand corner beside your name is a small arrow...click on that and you should get a drop down box & in the box you should see "user Control Panel" click on that & you will see profile click on that & on the left you sohuld see "edit Signature" that is where you enter the info........
I hope this helps........
Re: membership
That's where I was looking, but I don't see where I have that option.
Do you mean here.....
Re: membership
Maybe you do have to be a member; my screen similar to the one you posted has additional items that include "edit signature" :roll: :|
Re: membership
I thought that you were a full member..............Lee Help?
That is where I thought you had to go......You might have to be a member to do that......You have never joined the NTBA?
Re: membership
No, I have not joined yet.
Re: membership
Well that is probably the problem....Some things have been set aside for Members Only on the website...... :?: :?: :?: :?:
I did not find you in the member data that is used but I thought you may have been misplaced.........It only cost 35 bucks and you even get a T Shirt plus a Key ring for that much and you can access all the info on the website...it only cost 25 bucks a year after that come on an Join the Family.......... :)! :)! :)! :)! :)! :)! :)! :)! :)! :)! :)! :)! :)! .
Never mind Lee........
GTS225
Handle: GTS225
Re: membership
Post by GTS225 »
Say, Lee ; I attempted to access the "members only" forum, and got this; Members Only (Full NTBA Membership Required)
You do not have the required permissions to read topics within this forum.
Did I get missed during your busy adventures?
I don't expect instantaneous results, I've been following things, and know you're busy this, and next month.
Roger
Lee in KC
Handle: Lee in KC
Re: membership
Post by Lee in KC »
Sorry Roger, I did miss upgrading you when you joined NTBA. I have to rely on a 68-year-old's memory to check those things... :roll: You are now a full member!
GTS225
Handle: GTS225
Re: membership
Post by GTS225 »
Understood, Lee. I'm 8 months from 60 myself, and have already noticed a few of my memory cells seem to have been lost in the shuffle.
Thanks.....Roger
