VroomKrazy's T Coupe Project
VroomKrazy
Handle: VroomKrazy
Re: VroomKrazy's T Coupe Project
Thanks
Bill Holley
Handle: delawarebill
Post by Bill Holley »
nice project.. i like the fist pic of the frame.. has a mirror image or a reflection of work bench.. that's gonna be neat and engine sitting in mid air.. keep em coming..
Hey VroomKrazy,
Did you build that gantry crane? If so, any chance that you could send me a sent of the plans (rbswelder at yahoo.com)
Thanks in advance!
VroomKrazy
Handle: VroomKrazy
rbsWelder
I did build the crane but I have no plans. they cut up a painting cart at work and no one wanted the paint covered tube so I took it and then I found a cheap piece of 4x4 3/8 wall tube and kind of just threw it together.
Vroomkrazy
3/4 square tubing bent to each side a small bit then covered with .080 Aluminum....I think you could turn upside down and it would hold up.......
Then made some 3/4 wood strips to tack the cloth too some day.....
Underneath I put some dynamat for deadening and less heat......
I have some other photos if you want them........I sometimes like a little overkill ..... :)! :)!
Remember that top will a slope to the sides and to the front so the vinyl Mr Ford used would drain better......the door windows are shorter in the front than the back, don't ask me how I know for sure.......... :)! :)!
VroomKrazy
Handle: VroomKrazy
found 2 more doors
should be able to make a set of good doors out of 2 sets and some metal
VroomKrazy
Handle: VroomKrazy
rear 4-link mocked up
VroomKrazy
Handle: VroomKrazy
4-link tubes, radius rods, tie rod all cut and threaded.
VroomKrazy
Handle: VroomKrazy
hot rodding is so much fun :)!
Bill Holley
u are so correct.. the build was always fun for me.. but had to keep thinking 3 steps ahead so i didn't have to fall 4 steps back with a mistake.. it'll keep u thinking for sure
